Flush Routing Tables by VLAN
For administrative and troubleshooting purposes, sometimes you must flush the routing tables. You can use EDM to flush the routing tables by VLAN or flush them by port. Perform this procedure to flush the IP routing table for a VLAN.
  1. In the navigation pane, expand Configuration > VLAN.
  2. Select VLANs.
  3. Select the Advanced tab.
  4. In Vlan Operation Action for the VLAN you want to flush, double-click, and then select a flush option from the list.
    In a VLAN context, all entries associated with the VLAN are flushed. You can also flush the Address Resolution Protocol (ARP) entries and IP routes for the VLAN.
  5. Select Apply.
